I have a question regarding ip summary-address command in above lesson.
By applying ip aummary-address command in fastethrnet 2/0 interface,
how come heart router know about the summary address.
As my understanding ip summary address is per interface basis.
I should apply ip summary-address in fastethernet 1/0 interface.
Would you correct me and help me to understand better.
Hi Toral,
I just changed the picture because the interface number didn’t match. You configure a summary outbound on an interface facing towards your EIGRP neighbor.
Simple but effective workout to understand EIGRP summerizing
Thanks Django!
thanks for the nice lesson, keep up the good work
Rene, why is it /23 mask? when I see the first statement showing /24.
Spade(config)#<strong>interface fastEthernet 2/0</strong>
Spade(config-if)#<strong>ip summary-address eigrp 1 172.16.0.0 255.255.254.0</strong>
1st. statement.
Hearts#<strong>show ip route eigrp
172.16.0.0/24</strong> is subnetted, 2 subnets
D <strong>172.16.0.0</strong> [90/30720] via 192.168.12.1, 00:02:28, FastEthernet0/0
D <strong>172.16.1.0</strong> [90/30720] via 192.168.12.1, 00:02:28, FastEthernet0/0
Is it to cover 172.16.1.0 ?
Oscar
Hi Oscar,
That’s right, 172.16.0.0/23 covers both 172.16.0.0/24 and 172.16.1.0/24.
Can you show us more examples using summarization? it’s an easy topic but I would like to see another scenarios ![]()
Thanks!!!
Hi Diana,
Sure, anything particular you would like to see?
Hey Rene,
I am alittle confused with summarization over here. So taking your example over here, when we want to summarize subnets we used /23 subnet mask that is shared by all the subnets that we want to summarize and use it on interface level. But in your next lesson “no auto summarization” when we disable the “no auto summarization” we use wild card mask under eigrp configuration, what is the difference, why didn’t we use wild card mask over here ?
Best,
Tooryalai
Hi Tooryalai,
This can be confusing yes. Cisco isn’t very consistent with their usage of wildcards, subnet masks and CIDR notation. Sometimes it doesn’t make much sense ![]()
I have a doubt , how does summarization prevents the SIA issue ?
or in other words how does the neighbor knows not to send the query packet to this neighbor which is summarizing addresses to me !
thanks,
Amit,
Only on the router where the summarization is configured does the Query process stop–not on the router that originates the Query. So for example, if you have three routers A, B, and C with a topology of A—B—C. B has created a summary, say 10.10.0.0/16. Suppose Router A has a route 10.10.10.0/24 that goes active. Router A will still send the Query message to B, but B will see that 10.10.10.0/24 is contained within its own configured summary of 10.10.0.0/16. This will cause Router B to stop propagation of the Query to router C. Additionally, Router B will reply immediately back to A’s Query saying “Unreachable”
Hey,
Has anyone tested this in GNS3?
Can’t seem to get it working
R1
interface Loopback1
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.252
ip summary-address eigrp 1 192.168.0.0 255.255.252.0 5
duplex auto
speed auto
router eigrp 1
network 1.1.1.0 0.0.0.3
no auto-summary
R2
ip address 1.1.1.2 255.255.255.252
duplex auto
speed auto
router eigrp 1
no auto-summary
R2#show ip route
1.0.0.0/30 is subnetted, 1 subnets
C 1.1.1.0 is directly connected, FastEthernet0/0
R2#
Hello Ryan
I notice that in your show IP route command, no EIRGP routes show up. This tells me that for some reason, no EIGRP neighbours have been created. You should at least see the 192.168.1.0 and 192.168.2.0 subnets separately show up. Check the neighbour table to see that they have successfully created an adjacancy. Before you configure any EIGRP summarization, try to get EIGRP alone to function correctly. Then you can add the summarization commands.
I hope this has been helpful.
If the network is summarized, should not have an A.D of 5 in the neighbor routing table???
Hector,
No, it should not. The Administrative Distance of 5 for an EIGRP summary route is local only on the router that does the summarizing. When that summary is then advertised to a neighbor, the neighbor installs the summary with the regular AD of 90.
Hi Andrew,
Then, based on the exercise, it is in R1 where the route should appear with A.D. of 5.
R1#show ip route eigrp
172.16.0.0/16 is variably subnetted, 3 subnets, 2 masks
D 172.16.0.0/23 is a summary, 00:01:38, Null0
where we can check the A.D.?? Since it does not appear.
And thanks for ur reply ![]()
Hector,
To check the AD of the route, issue:
#show ip route 172.16.0.0 255.255.254.0
