Can we redistribute OSPF one area in to OSPF different area?
Hi Sathmal,
Nope itâs impossible, you canât redistribute one process into the same process.
I am confused with the following redistribution command: metric-type 1 when redistribute between eigrp into ospf.
R3(config)#router ospf 1
R3(config-router)#redistribute eigrp 100 metric-type 1 subnets
Thank you for this lesson.
what exactly is the use of the âdefault-metricâ command? While redistributing routes can i use any metric in the command?
Example:
John(config-router)#redistribute ospf 1 metric
Hi Abhishek,
If you redistribute into EIGRP or RIP then the default metric is set to âinfinityâ. You can use the default-metric command to set a default metric globally or configure it each time when you use the âredistributeâ command.
Hi Achilleas,
OSPF has two types of external prefixesâŚE1 and E2.
The cost of E2 remains the same within all OSPF areas (default cost 20) while the cost of E1 increases, just like any other prefix.
This command is required to choose if you want E1 or E2.
I a have doubts about the command line redistribute ospf 1 metric 5, specific on the hop counts. I see you set the number to 5, why shouldnât I put 2,3 or maybe 7,8 etc.?? Is there a rule in which indicate what number should go there? I have seen in a few textbooks and videos that instructors put ârandomâ numbers there without explaining the implication of using a very high number or low.
Can you please advice?
Hi Jose,
When you only have one router that is redistributing something into RIP, it really doesnât matter what hop count you pick. Just make sure that the hop count never exceeds 15 anywhere in your network or you will have reachability issues (16 is unreachable).
When you have two routers doing redistribution, itâs a different story. When R1 sets a hop count of 1 and R2 sets a hop count of 5 or something else, all routers will prefer the redistributed path through R1 since the hop count is lower.
Does that make sense?
hi mr rene
Sathmal June 20, 2014 at 9:24 am #
process id is local significant within a route, i dont understand you ans, plz can you help me?
Hi Emanuel,
Redistribution is used between different routing protocols, for example EIGRP - OSPF or RIP - OSPF. When you run multi-area OSPF, you donât need redistribution since areas already share certain LSAs.
thank you mr RENE
mr rene could you help me the concept of prefix list(ge and le)???
Sure, hereâs an example:
Do you have a lesson showing redistribution between OSPF and EIGRP?
Hi Jason,
The commands are similar.Hereâs an example how you could redistribute both ways between OSPF and EIGRP:
R1(config)#router ospf 1
R1(config-router)#redistribute eigrp 1 subnets
R1(config)#router eigrp 1
R1(config-router)#redistribute ospf 1 metric 1 1 1 1 1
Hi ,
Thankyou for tutorial
I just want to ask when we redistribute ospf and rip then why dont at r1 we see ospf neig r3 and at r3 rip neig r1
Hello Apurva
When routing information is redistributed between two different routing protocols such as in Reneâs example, each region where each protocol functions is autonomous. This is because routers in each region only âspeakâ one language, either OSPF or RIP. The router on the border of the two regions âspeaksâ both languages and does the translation between the routers.
This means that R1, which understands OSPF, will only create a neighbour relationship with R2. As far as R1 goes, it only âknowsâ of R2 and nothing else. R3 is non existent.
The same goes for R3, its source of RIP routing information is R2 which speaks its language. It knows nothing of R1.
Now, R1 does LEARN the routes to R3, but it learns them from R2 and not directly from R3. Similarly, R3 does LEARN the routes to R1 but it again learns them from R2.
There is no direct interaction between R1 and R3.
I need little more help in understanding. in the link you provide it says the following about E1 saying use this when you use multiple ASBR.
NOTE: If the metric-type argument is not used, routes will be advertised by default in OSPF as E2 routes. E2 routes have a default fixed cost of 20 associated with them, but this value can be changed with the metric keyword. The metric will not change as the route is propagated throughout the OSPF area. E1 routes will have internal area costs added to the seed metric.
Then they go on to say use E2 when you only have a single ASRB
I get the what they say directly if more use this if only a single use this. My question is the following:
an example from the webpage: (config-router)#redistribute eigrp 10 metric-type 1 subnets
It looks like metreic-type 1 is the portion of the command that controls E1 or E2 though E2 is the default so probably is not required to be added manually. I guess I need to stop being lazy at this point and lab it up and see what happens when I use the command to help figure it out and cement it in my brain. I will do that now lol.
Have built my GNS3 topology off theirs now adding the configuration will report back my findings soon as I get there:
So while following their configurations they first had us go into the EIGRP and change the metrics. At first this confused the hex out of me and the reason it confused me was because it was not needed. I donât know if they are just doing some reminder of EIGRP configuration here or what. I will admit it was helpful because I had to combine EIGRP with OSPF and since I have been studying OSPF I was getting a bit forgetful on the EIGRP as I have not yet brought the two studies together.
So very informative but after identifying what was going on I decided to leave out changing the EIGRP metrics. if you want to comment on this feel free if you think they did this for a different reason than teaching and reminding.
Next I went to their command to redistribute this was very simple and since we do not specify the E1 route it uses the default which is the E2 which always has a metric of 20. See pics below which illustrate
Now something of importance and you see it noted in the picture above is the subnets key-word I had to jump ahead in Renee lessons to understand this to his Redistribution chapter which covers redistribution between OSPF and RIP see link How to configure Redistribution between OSPF and RIP In studying this forum post specifically I am coming across information I had not learned yet is all. Below is my output when I checked my WINNIPEG router which is according to my topology my furthest router in OSPF area 0. You can see sure enough it redistributed those routes as E2 the default with their metric cost of 20.
Next it was finally time to test the command to manually change this and then witness the results:
And as you can see I changed it to E1 and this was sent over to my WINNIPEG Router:
This should help me when I go over Rene lesson on Redistribution as well and reinforce the metric stuff.
That helped a lot Las.
Can you give some basic information on why they are saying in the tips to use E1 if have multiple ASBR and use E2 if you have single? I want to get into their heads to understand their strategy on why and when to use. I am guessing it has to do with this:
its just not clicking into place on the strategy of their choice. ![]()
Hi @wilder7bc,
If you redistribute something into OSPF, the E2 route will have a fixed metric, the E1 route will have a metric that increases throughout the network, itâs the same as with normal OSPF routes.
So why do they use E2 vs E1? Letâs look at some examples. Letâs say the red box is OSPF and blue is some other routing protocol.
Scenario 1
There is only one router doing redistribution so it doesnât matter what the metric isâŚyou can only go through R1 if you want to get to the other side. You can use either E2 or E1, it doesnât matter.
Scenario 2
Here we have R3 and R4 doing redistribution. If you use E2 here, the metric for the redistributed routes is the same everywhere in the OSPF domain. That means that R1 will use R3 and R4 to get to any redistributed route. It works, but itâs not optimalâŚR4 is located one hop further away from R1 compared to R3. In this case, itâs better to use E1 since it metric increases throughout the domain.
Hope this helps!
