I am learning CCNA R&S now and your lesson is very helpful. Thanks.
I am CCNP R&S, your lessons help me to refresh all the topics.
Very well explained.
Your way of explanation is so nice. I have understood very well about VLAN.
thank you verrrrrry much.soooo useful:)
You are welcome!
Thank you, I use this web site for the first time,
It’s a good lesson, it’s easier to understand it
Hi Reno,
Great and very well explained
gr8, well explained
Excellent. Very nicely explained, just like the other videos. Keep up the great work. It’s helpful.
Do u have ccie complete book? Great work
Hi Sihle,
Not at the moment, maybe sometime I will convert a lot of posts here into a book but for now I’ll publish everything that I create online here on networklessons.com.
I learned from http://www.netcontractor.pl/blog/?p=184 that control traffic from Layer 2 protocols like ( DTP, VTP , CDP , PAgP , STP, etc ) use VLAN 1.
And I make sure of that by doing this experience :
- I made a simple topology of connection two switches and making connectivity as trunk.
- I made one switch VTP server and another as VTP client.
- I also setup RSPAN to monitor the packets.
- Results, I saw VTP, CDP traffic marked with VLAN ID 1.
- Then, I made another vlan and disallowed Vlan 1 in the trunk.
- Results still the same.
- I thought it might be that traffic might be sent untagged as native vlan, so then i changed the native vlan on both switches, expecting that either VTP, CDP will fail OR it will be marked as VLAN ID of new native vlan.
- However, to my surprise it was still showing as VLAN ID 1.
- So I’m baffeled and confused on this type of behaviour where Vlan 1 is NOT allowed in trunk and also native vlan has been changed, still VTP and CDP control traffic is shown as sourced from Vlan 1.
After this experience I have only one question ?
As I know that it is work, so my question is not whether should work or not work… But how actually it is working? I mean how does these protocols use VLAN 1 when it’s not allowed in trunk port or even when it’s shutdown ? can you shed some light please and explain how the packet is send on vlan 1 despite it pruning on trunk because I’m very confused ?
Hi Hussein,
First of all, it is indeed confusing. By default VLAN1 is the native VLAN and it’s untagged.
I do believe however that “control” frames like VTP, CDP, DTP, etc. don’t really belong to a VLAN. They are untagged and like you have seen, even when you block VLAN1 then this traffic is still sent and received.
I must agree with every one else that you are a talented teacher.
Brilliant work.
Hi Rene, what do you think what is a sensible number of hosts to have in a broadcast domain before splitting up the network into VLANs? Do you have any experience from the field about that? Thanks, Daniel
Hi Daniel,
There’s a “technical” and “practical” aspect to this question ![]()
Let’s start with the technical part…a lot of networking people will tell you that you shouldn’t have > 200 hosts in a subnet since there will be too much broadcast traffic and it will slow down your network. This might be true 10 years ago but nowadays, your computers won’t be bothered much with broadcast traffic and it shouldn’t be an issue for your switches. You could probably put ~1000 hosts in a single subnet and not notice any performance issues.
The more important issue (the practical aspect) is that a single subnet/VLAN is one failure domain. Let’s say we put 1000 hosts in a single subnet and one computer has a broken NIC, sending non-stop garbage broadcast frames. This will affect the entire VLAN and your 999 remaining hosts.
By breaking down this big VLAN into four smaller VLANs, a broken NIC would only affect one VLAN…not the other three.
So for practical reasons I think it’s best to stick with /24 subnets. They are easy to work with and you’ll have multiple failure domains.
So if I have a 48 port switch on the 198.168.1.0/24 network….. and all 48 ports are connected to host. All the host have IP addresses on the 198.168.1.0/24 network. And lets say I create 4 VLANs. Help Desk is on VLAN 10 (interface 1-12), MGMT is on VLAN 20 (int 13-24), Accounting is on VLAN 30 (int 25-36), and Supply is on VLAN 40 (int-37-48). OK…. So these 4 VLANs would basically share the same network (198.168.1.0/24) right? VLANS don’t have to be on different networks/subnets?
What if there were some other MGMT host on another router on a 10.10.10.0/24 network…. Could those join the above VLAN 20 as well?
Jason,
Except in the unusual case of Private VLANs, VLANs are 1:1 with subnets. When you assign ports to VLANs on your switch, you will have to think about what will be the layer 3 device that connects them together. If your switch is a layer 3 switch, the switch itself can route traffic between your VLANs. Otherwise, you will need a separate router to do it.
Your MGMT host could be part of VLAN 20, but you would need to make sure that all the hosts in VLAN 20 share the same 10.10.10.0/24 network as MGMT.
