Network Fundamentals Lab 1
I realize that it’s not what the requirements are, but in my opinion it is good to mention that it is not a good practice. It’s not recommended to use dynamic trunking and its not recommend
to use routing on access switches in a campus network. It makes it more complicated and its prone to more errors. You should not want to teach the wrong practices. That’s the reason I brought this up.
Best regards,
Michael
Hello Michael
Thanks so much for your kind words. We do our best here, and the feedback we get from users like you helps us to improve continually, so the time you spend in this thread is appreciated!
Yes, I understand, it’s not always easy when doing the lab from a long document on a web page on the screen. Separating it into two different labs is a solution, and for learning, that’s fine. Keep in mind that implementing both IPv4 and IPv6 in the same lab is essential as well, as having both protocols running on the same topology is a common real-world scenario. So gaining experience in that is also crucial.
In section 4.5.2 DHCP config for the hosts is explained, and is achieved using an IP helper address. OSPF is applied to the ASWs only for the purpose of advertising the loopback and the management SVI, not for the hosts themselves. OSPF is necessary on the DSWs to make the IP helper address reachable.
I see now that the final configs don’t have that OSPF configuration on the ASWs, which I believe is one of the issues that you pointed out, so I will let Rene know to make that correction. In the lab, however, Rene does include the management VLAN and the OSPF configuration for the ASWs as he suggests in this post.
Again, I understand the difficulties that this can bring, but if you have a topology with both IPv4 and IPv6, then you need a protocol to serve them both. You can run OSPFv2 for IPv4 and OSPFv3 for IPv6, or you can run OSPFv3 for both. Learning to implement these technologies together is always helpful to enrich your skillset. Although Cisco doesn’t explicitly mention this in its blueprint, it is always possible that they will add related info, so gaining experience in these kinds of scenarios always helpful.
Both the show ipv6 ospf neighbor and show ospfv3 neighbor commands are correct, they just behave a bit differently.
The show ipv6 ospf neighbor command displays the IPv6 OSPFv3 adjacencies only. This is an older command, but still valid, from the time when OSPFv3 was IPv6 only. In order to see all address families (IPv4 and IPv6) the show ospfv3 neighbor command is preferred. Since we have both IPv4 and IPv6 addresses being shared in the lab, it may be worth using the show ospfv3 neighbor command. I will make the suggestion to Rene to consider adding that.
I will let Rene know to look over your suggestions and consider any necessary changes to clarify them.
We really appreciate the time you spent sharing these things with us. Your feedback is invaluable!
Hi Michael,
Thanks for sharing all of this. Let me jump in on a couple of things.
When I created this lab, the tasks are in order of L2 > L3 > Routing > All other items, and for both IPv4 and IPv6. When you configure IP addressing, I added both IPv4+IPv6.
It could be easier to start with the IPv4 tasks, get them working, and then get back and do all the IPv6 tasks. There is some “context switching” now between IPv4 and IPv6.
This is a thing of in-band vs out-of-band (OOB) management. Having OOB has the advantage that your management traffic is completely separated from the production network. If you mess up something, you won’t have issues that affect the production network or lock yourself out. It might also be required for security reasons. You’ll need additional equipment for this management network. In-band management is effective because you run it on your network, which is already up and running, with the downside that you can affect your production network. If you mess up, you can lock yourself out.
This is a design question. On the access layer, you can do L2 or L3. If you use L2 on the access layer, you’ll be able to span VLANs over multiple access layer switches. You’ll have to deal with STP and gateway redundancy protocols like HSRP/VRRP on the distribution layer switches.
You can also run L3 on the access layer switches. VLANs will be local to a single access layer switch, but you won’t need HSRP/VRRP anymore, and you’ll be able to use all links for forwarding because of ECMP.
I’ll go through the lab again to see what I can improve. I think I did something with OSPF on the access layer switches because there’s a chicken-and-egg scenario where if you don’t use routing, the access layer switches require a default gateway, which doesn’t work yet because you would configure HSRP/VRRP on the distribution layer switches. For labs like these I prefer to create tasks where you can go through from A > Z where one task builds on another.
Hello, I’m trying to configure the Network Fundamentals Lab but I have a question. What image are you using for the switches?
Hello Corwyn
The lab images are shown in the Solution section here.
Specifically:
  • Switches: Cisco IOS Software, vios_l2 Software (vios_l2-ADVENTERPRISEK9-M), Experimental Version 15.2(20200924:215240) [sweickge-sep24-2020-l2iol-release 135]
  • Routers: Cisco IOS Software, IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.9(3)M6, RELEASE SOFTWARE (fc1)
I’m not currently working. To keep my skills fresh I’m going through this and the other labs available. There are some perceived challenges with the lab. Mostly around wording, order, and design preferences. However, this is to be expected. We don’t all build networks, or labs, the same way.
I also made some assumptions and/or misread things in my haste. For example, I just assumed the SVIs would reside on the core and we’d run L2 all the way down to the access layer. What i realize now is that back in the days before we moved to collapsed cores and spine/leaf we used to place the SVIs at the distribution layer. In hindsight I should’ve read the lab end-to-end before starting it. I should’ve also read the comments.
These mistakes are learning, or in my case, re-learning opportunities. The best Engineers can admit their mistakes, adapt, and learn from them. There’s also a lot to be said about putting yourself in the thought process of others. Asking why someone did something the way they did also presents learning opportunities
Thanks for these labs. Great Job!
Hello James
Thanks so much for your comments. It’s always helpful to get into the heads of those engineers who are going over the material on the site.
The way things are written and expressed is always an issue when it comes to networking and determining the requirements, and it’s something we need to address and deal with. As you probably already have experience in this, the decision-makers and the money-handlers are often not networking professionals, and they too must understand, at a higher level, what is being implemented, and why it is necessary, and that is often the greatest challenge of all! As you suggest, it’s a good exercise to use this lab for understanding the initial requirements as well.
Concerning the SVIs, you’ve identified one of the most important architectural concepts in campus network design, which is, where to place SVIs and where to draw the Layer 2/Layer 3 boundary. More about this can be found at this lesson. Your assumption about SVIs at the core is just a different, equally valid design model, depending on the specific situation. But it does stress how important it is to read the requirements fully before starting up, as you have mentioned in your post.
Again, your input and insight are valuable, and I’d like to thank you for sharing!!
Great lab. I do have a question regarding the spanning-tree values for max-age. The instructions indicate, “A configuration BPDU should expire after 15 seconds.”
I used the following command “spanning-tree vlan 10-40 max-age 15“. However, you put the value at 20, spanning-tree vlan 10 max-age 20
Why is it not 15 instead of 20?
Hello Roger
Yes, that’s an excellent question, and may require some additional explanation in the text of the lab solution itself. It’s important to understand the relationship between the “BPDU Expiration” and the max-age value.
After how long the BPDU expires, and the max-age timer are not the same thing. According to Cisco’s official documentation, BPDU expiration time is calculated like so:
  • BPDU Expiration Time = Max Age - Message Age
Message Age is a counter that tracks how far a BPDU has traveled from the root bridge. The root bridge sends BPDUs with message age = 0, and each subsequent switch adds 1 to the message age before forwarding the BPDU.
So a BPDU that is received by a switch from a root bridge will have a message age of 1, and if the max age is set to 20, the BPDU will expire in 20 - 1 = 19 seconds. Now if the BPDU a switch receives traverses 5 bridges, resulting in a message age of 5, when that switch receives it, it will have a BPDU expiration time of 20 - 5 = 15 seconds.
Now the topology in the lab has a maximum diameter of 5 hops, which means that the maximum message age a BPDU message can have is 5. So by using a max age of 20, the minimum BPDU expiration time on the specific topology will be 20 - 5 = 15.
I will let Rene know to make some clarifications on the lab to make sure that this point is expressed more clearly. Thanks for engaging and sharing your experience!
