QoS on Cisco 4500-X
I’m trying to set up a QoS template that I can implement and edit/update at other sites with similar requirements. I’m doing this on a 4500-X VSS Switches. I can set class-maps and Policy-maps, but can either do Priority or bandwidth inside the Policy->Class. Meaning I can’t set a Policy-Map → class
We have multiple VoIP providers ( all soft phones ) and I’d really like to set DSCP EF for Priority and a percent of the bandwidth. I was pointed to this site: https://www.ciscopress.com/articles/article.asp?p=2756478&seqNum=8 and it describes a 4, 8. 12 config I still have couple questions..
For example the 8-class QoS strategy..
Voice: Marked with EF and limited to 10 percent of link bandwidth in a strict-priority queue
– Is this telling me that traffic marked as EF will get Priority 10% and only 10% of link bandwidth
Multimedia conferencing (Interactive video): Marked with AF41 or sometimes as EF and limited to 23 percent of link bandwidth in a strict-priority queue
– Is this telling me that traffic marked as AF41 will get 23% and only 23% of link bandwidth
Are the bandwidths set in a template in the IOS, and are there more auto bandwidth settings? For example traffic marked as AF32. Is there a pre-built min / max for that marking?
Does the priority setting within the class of the Policy just set that class as priority → first out? For example my class for EF traffic I set priority for that class in the Policy Map 10% of the first out data..
If I set priority and "remaining Bandwidth percent <> I’m assuming the delivery of the packet is based on the marking… So a AF41 is going to go before a AF11 ( AF43 for that matter ) and does the AF41 queue have to be empty before the AF11 will hit the line?
Policy Map primary-eth-1G
    Class qos-any-ef
      priority
    Class qos-control
      bandwidth remaining 5 (%)
    Class qos-sip-signaling
      bandwidth remaining 3 (%)
If I have traffic entering the switch marked as EF can I change that to something else like CS4 or AF41 via: ACL → class-map → Policy-map config. Before it hits the EF class-map? We have Zoom running and currently the app is tagging traffic as EF. I’d like to have my Voice take precedence over Zoom all the time..
Hello Aaron
I’ll try to address your concerns so that you can have an idea of how to proceed from here.
This is how policy maps are set up. You cannot configure both priority and bandwidth, but either one. However, I believe what you are looking for is to configure a maximum allowed bandwidth for the priority queue. That can indeed be configured simultaneously and it is achieved using the policing feature.
Consider looking at the 4-class QoS strategy, as that provides a more suitable scenario for your situation, since you don’t need so many QoS classes.
OK there are a couple of issues here. If your voice is marked with EF, and your interactive video is also sometimes marked with EF, then you must find a way to differentiate them. This can be done either by matching an access list for particular ports (rather than QoS markings), or by changing the QoS markings on those particular packets. More on the latter later.
You can also use what is known as multi-level priority queues, which are further described in the following Cisco documentation. It may however not be supported on your platform:
Now does that mean that only 23% will be used? There is what is known as an implicit policer implemented in these cases, so yes. Take a look at this post which may give you some more information about this:
If you create a policy map that identifies the Zoom traffic (using IP address or port numbers for example) and place it incoming on the appropriate interface, you can use that policy map to change the QoS marking to whatever you like. Then they will reach the EF class map with the appropriate marking and you can treat them differently from your other traffic since you can now differentiate between them.
For most of the other questions, take a look at the following lesson:
Thanx Laz, very… I’ve been working on this and took my overly complicated design and stripped it down to what you were referring to. I’ll post shortly… With regards to re-marking the Video off EF to something else… Can I use the same class-map in the ingress policy-map ( to remark the incoming packets) as the Egress policy-map to designate the bandwidth? I’ll have that in my config here shortly..
! ------- Policy Maps
Policy Map primary-eth-1G  ! - applied to Egress to ASA
  Class PRIORITY-QUEUE
   priority  ! - 10%
 Class CONTROL-QUEUE
 Class SCAVENGER-QUEUE
   bandwidth remaining 1 (%)
 Class SIGNALING-QUEUE
   bandwidth remaining 2 (%)
 Class VIDEO-QUEUE-EGRESS
   bandwidth remaining 25 (%)
 Class class-default
  bandwidth remaining 67 (%)
  dbl
  Policy Map ingress-internal  ! - applied to Etherchannels inside facing
   Class VIDEO-QUEUE-INGRESS
   set dscp af41
! ------- Class Maps
Class Map match-all TRANSACTIONAL-DATA-QUEUE (id 12)
 Description: Mission Critical Data Apps
 Match   dscp af21 (18) af22 (20) af23 (22)
Class Map match-any VIDEO-QUEUE-EGRESS (id 13)
 Description: matching marked video traffic
 Match   dscp af41 (34)
Class Map match-any SCAVENGER-QUEUE (id 6)
 Description: Matching Scavenger Class
 Match   dscp cs1 (8)
Class Map match-any SIGNALING-QUEUE (id 7)
 Description: Matching Signaling
 Match   dscp cs3 (24)
Class Map match-any class-default (id 0)
 Match any
Class Map match-any CONTROL-QUEUE (id 8)
Description: Matching Network Control
Match   dscp cs6 (48)
Class Map match-any VIDEO-QUEUE-INGRESS (id 11)
 Description: capture ingress video traffic
 Match access-group name CONF-ROOMS  ! - access list matches source and destination of conf room subnet
Class Map match-all PRIORITY-QUEUE (id 10)
 Description: Matching Voice
 Match   dscp ef (46)
Hello Aaron
Yes, you can reference the same class map in multiple policy maps.
As for your configurations, everything appears to be good. Have you tried it out to see it in action? Let us know how it goes…
Checked this morning, I’m a little concerned about drops. Our office is empty ( nothing happening ), yet I still see drops.. Is that to be expected?
core#show policy-map interface te1/1/15
 TenGigabitEthernet1/1/15
Service-policy output: primary-eth-1G
queue stats for all priority classes:
  Queueing
  queue limit 1520 packets
  (queue depth/total drops) 0/8
  (bytes output) 17487321
Class-map: PRIORITY-QUEUE (match-all)
  26467 packets
  Match:  dscp ef (46)
  Priority: Strict, b/w exceed drops: 8
Class-map: CONTROL-QUEUE (match-any)
  893 packets
  Match:  dscp cs6 (48)
    893 packets
  Queueing
  (queue depth/total drops) 0/40
  (bytes output) 1060490
  bandwidth remaining 5%
Class-map: SCAVENGER-QUEUE (match-any)
  0 packets
  Match:  dscp cs1 (8)
    0 packets
  Queueing
  (queue depth/total drops) 0/0
  (bytes output) 0
  bandwidth remaining 1%
Class-map: SIGNALING-QUEUE (match-any)
  145 packets
  Match:  dscp cs3 (24)
    145 packets
  Queueing
  (bytes output) 9280
  bandwidth remaining 2%
Class-map: VIDEO-QUEUE-EGRESS (match-any)
  4251043 packets
  Match:  dscp af41 (34)
    4251043 packets
  Queueing
  (queue depth/total drops) 0/13
  (bytes output) 843854740
  bandwidth remaining 25%
  118347632 packets
  Match: any
  Queueing
  queue limit 3072 packets
  (queue depth/total drops) 0/170
  (bytes output) 21866728830
  bandwidth remaining 67%
  dbl
      Probabilistic Drops: 0 Packets
      Belligerent Flow Drops: 0 Packets
core#
Hello Aaron
Some good and sound troubleshooting advice for such drops can be found at the following CIsco documentation:
Take a look at this and see if you can identify the reasons for the drops. Let us know your results.
Thanx Laz, looks like the show mls command isn’t available on this platform… I’m trying to work with Cisco and troubleshoot some more.. I do have a follow up question though on QoS in general..
I have another question on config… I have my class-maps listed below and I was wondering if you could help me understand why some match lines seem to be added… Also if I do a show run class-map | e VSL there are some variations to what I configured. Is this like ACL’s in a where show access-list will show all permutations of the ACL?
ir01_mdf_core#show class-map | e VSL
! - The below matches af41 - af23 were not added by me to this class
   Match   dscp af42 (36)
   Match   dscp af43 (38)
   Match   dscp af31 (26)
   Match   dscp af32 (28)
   Match   dscp af33 (30)
   Match   dscp af22 (20)
   Match   dscp af23 (22)
   Match   dscp cs1 (8)
   Match   dscp cs3 (24)
   Match any
! - The below matches af46, cs4, and cs5 were not added by me. I’m not sure why we would even have ef in the default class anyways
   Match   dscp ef (46)
   Match   dscp cs4 (32)
   Match   dscp cs5 (40)
   Match   dscp cs6 (48)
   Match   dscp ef (46)
! - The below matches were not added by me ca2, cs3, cs6, AND cs7
   Match   dscp cs2 (16)
   Match   dscp cs3 (24)
   Match   dscp cs6 (48)
   Match   dscp cs7 (56)
ir01_mdf_core#
ir01_mdf_core#
ir01_mdf_core#
ir01_mdf_core#
ir01_mdf_core#show run class-map | e VSL
Building configuration...
Current configuration : 1787 bytes
 match any
class-map match-all TRANSACTIONAL-DATA-QUEUE
  description Mission Critical Data Apps
 match dscp af21  af22  af23
 match dscp af41
 match dscp af42
 match dscp af43
 match dscp af31
 match dscp af32
 match dscp af33
 match dscp af21
 match dscp af22
 match dscp af23
class-map match-any VIDEO-QUEUE-EGRESS
  description matching marked video traffic
 match dscp af41
class-map match-any SCAVENGER-QUEUE
  description Matching Scavenger Class
 match dscp cs1
class-map match-any SIGNALING-QUEUE
  description Matching Signaling
 match dscp cs3
 match dscp ef
 match dscp cs4
 match dscp cs5
class-map match-any CONTROL-QUEUE
  description Matching Network Control
 match dscp cs6
class-map match-any VIDEO-QUEUE-INGRESS
  description capture ingress video traffic
 match access-group name CONF-ROOMS
class-map match-all PRIORITY-QUEUE
  description Matching Voice
 match dscp ef
 match dscp cs2
 match dscp cs3
 match dscp cs6
 match dscp cs7
Hello Aaron
Yeah, sorry about that, the 2960-X, 3560-X, and 3750-X are the last switches to use MLS. The 4500 uses Modular QoS Configuration (MQC) like routers.
So those extra matches that you see are from the default class maps that are generated by AutoQoS based on the Cisco Validated Designs (CVD). Even with a config out of the box, you’ll see those there.
Great thank you…
