Zone Based Firewall Configuration Example
according to Zone Self rule.
R2(config)#policy-map type inspect WAN-TO-SELF
R2(config)#zone-pair security WAN-TO-SELF source WAN destination self
R2(config-sec-zone-pair)#service-policy type inspect WAN-TO-SELF
Will all the data send back from ISP to LAN be dropped because of R2 Zone Self rule?
Hi @naingnnlwin,
The self zone is only for packets that are destined for the router itself, not for packets that are flowing through the router (like from WAN to LAN).
If you want to permit return traffic that originated from the LAN to the Internet, then you’ll need to use a inspect rule in your LAN-TO-WAN zone-pair.
thank for your explain.
Nyi Nyi.
When I apply the WAN_TO_SELF service policy as shown in this lesson, as expected R3 cannot ping R2, but R2 also cannot ping R3. Is this expected? Since there is nothing applied in the self > WAN direction I expected that R2 would still be able to ping R3.
Thanks for the great lesson!
Hello Jeremy
Remember that a ping has communication occurring in both directions. When you ping from R2 to R3, you are sending an echo request. This echo request reaches R3, which replies with an echo reply. This reply does indeed go from WAN to Self, so it is caught by the service policy you applied.
Could yo give an example when you can use the pass action instead of the inspect action?
Hello Rodrigo
Such a configuration would not be much different than the one shown in the lesson. The difference is that instead of the inspect keyword, the pass keyword would be used. Now the difference in the behaviour would simply be that the traffic would be passed without any regard to any return traffic.
The pass action would be used in scenarios where there is no session (non TCP traffic such as UDP) or scenarios where there is only one way traffic, such as multicast video (broadcast IPTV for example). Even in these cases however, you may have to provide for a method of communication in the opposite direction (possibly another pass action command) so that traffic travelling in the opposite direction that is associated with such applications (control information etc) can make it through the firewall.
Please can someone advise if there is option to configure zones on Cisco CSRv , has anyone done that setup?
Thanks in advance for your response
Hello Zeeshan
You can indeed configure a zone-based firewall on the CSR1000v in the same way as you would do so on a physical IOS device. You can find more information about this at the following link:
Thanks for the link, I’m a bit confused on how to proceed with CSR1000v, which is also serving as a VPN end point. I’ve read the above thread and see Simon has asked smiliar question and Rene has responded with an example config. However my confusion is, I’m using GRE+IPSec on CSR1000v. Will I have to assign the virtual interfaces tunnels to separate zones? Or only the OUTSIDE interface ( having cryptomap) will be in a zone? Please can you advise?
EDIT:
I’ve tried to apply below configs, however the GRE over IPsec breaks then BGP adjacency is lost between the CSR and remote end FW as soon as I put CSR’s interfaces in security zone. The CSR is behind a NAT router. I’ve attached the topology for reference.
please can you help me point where i’m making the mistake?, i’d really appreciate your support, please.
  CSR2#sh run
Building configuration...
Current configuration : 5638 bytes
! Last configuration change at 19:14:15 UTC Sun May 31 2020
version 16.3
no platform punt-keepalive disable-kernel-core
platform console serial
hostname CSR2
boot-start-marker
boot-end-marker
enable secret 5 $1$WETh$nFwuPGMClHjYlweGRS1Nb1
aaa new-model
aaa authentication login tacgui group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
ip dhcp excluded-address 10.40.40.1
ip dhcp pool Private
 network 10.40.40.0 255.255.255.0
 default-router 10.40.40.1
subscriber templating
crypto pki trustpoint TP-self-signed-743922911
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-743922911
 revocation-check none
 rsakeypair TP-self-signed-743922911
crypto pki certificate chain TP-self-signed-743922911
license udi pid CSR1000V sn 9RWZ8WIVQ1V
diagnostic bootup level minimal
spanning-tree extend system-id
username local password 0 local*123
redundancy
class-map type inspect match-any Internet-cmap
 match protocol icmp
 match protocol tcp
 match protocol udp
 match protocol http
 match protocol https
 match protocol pop3
 match protocol pop3s
 match protocol smtp
class-map type inspect match-all ICMP-cmap
 match access-group name ICMP
class-map type inspect match-all IPSEC-cmap
 match access-group name ISAKMP_IPSEC
class-map type inspect match-all SSHaccess-cmap
 match access-group name SSHaccess
policy-map type inspect inside-outside-pmap
 class type inspect Internet-cmap
  inspect
 class type inspect ICMP-cmap
  inspect
 class class-default
  drop
policy-map type inspect Outside-Router-pmap
 class type inspect SSHaccess-cmap
  inspect
  inspect
 class type inspect IPSEC-cmap
  pass
 class class-default
  drop
policy-map type inspect outside-inside-pmap
  inspect
 class class-default
  drop
zone security OUTSIDE
zone security INSIDE
zone-pair security INSIDE-TO-OUTSIDE source INSIDE destination OUTSIDE
 description INSIDE-TO-OUTSIDE TRAFFIC
 service-policy type inspect inside-outside-pmap
zone-pair security OUTSIDE-TO-INSIDE source OUTSIDE destination INSIDE
 description OUTSIDE-TO-INSIDE TRAFFIC
 service-policy type inspect outside-inside-pmap
zone-pair security OUTSIDE-TO-ROUTER source OUTSIDE destination self
 description OUTSIDE-TO-ROUTER TRAFFIC
 service-policy type inspect Outside-Router-pmap
crypto keyring KEY_RING
  pre-shared-key address 0.0.0.0 0.0.0.0 key cisco123
crypto isakmp policy 10
 encr aes
 authentication pre-share
 group 2
 lifetime 28800
crypto isakmp profile IPROF
   keyring KEY_RING
   match identity address 0.0.0.0
crypto ipsec transform-set TSET esp-aes esp-sha-hmac
 mode tunnel
crypto ipsec profile IPSECPROF
 set transform-set TSET
crypto map MYMAP 10 ipsec-isakmp
 set peer 192.4.10.2
 match address 101
interface Tunnel1
 ip address 10.1.1.0 255.255.255.254
 zone-member security OUTSIDE
 tunnel source GigabitEthernet1
 tunnel destination 192.4.10.2
interface GigabitEthernet1
 ip address 10.11.0.2 255.255.255.0
 negotiation auto
 no mop enabled
 no mop sysid
 crypto map MYMAP
interface GigabitEthernet2
 ip address 10.40.40.1 255.255.255.0
 zone-member security INSIDE
 negotiation auto
 no mop enabled
 no mop sysid
router bgp 65000
 bgp router-id 15.15.15.15
 bgp log-neighbor-changes
 network 10.40.40.0 mask 255.255.255.0
 neighbor 10.1.1.1 remote-as 65001
virtual-service csr_mgmt
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.11.0.1
ip access-list extended ICMP
 permit icmp any any echo
 permit icmp any any echo-reply
 permit icmp any any traceroute
ip access-list extended ISAKMP_IPSEC
 permit udp any any eq non500-isakmp
 permit udp any any eq isakmp
 permit ahp any any
 permit esp any any
ip access-list extended SSHaccess
 permit tcp any any eq 22
access-list 101 permit ip host 10.11.0.2 host 192.4.10.2
tacacs server tacgui
 address ipv4 10.40.40.3
 key cisco123
control-plane
line con 0
 logging synchronous
 stopbits 1
line vty 0
 login authentication tacgui
 transport input telnet ssh
line vty 1
 length 0
line vty 2 4
Hi Rene/Laz,
I’ve managed to get the VPN working.
However I’ve a different question regarding the class-map. this is my class-map for VPN traffic
 class-map type inspect match-any vpn-cmap
 match protocol dns
  match protocol ssh
  match protocol telnet
  match protocol tacacs
  match protocol icmp
  match protocol udp
  match protocol tcp
and these are the policy map
policy-map type inspect vpn-inside-pmap
 class type inspect vpn-cmap
  inspect
 class class-default
  drop
policy-map type inspect inside-vpn-pmap
  inspect
 class class-default
  drop
Issue is even though the class-map is not having ā€œmatch protocol https or httpā€ i’m still able to open a https page in side of VPN zone. Only time i’m not able to open https is when i remove ā€œmatch protocol tcpā€
please can you explain why? and is having an access-list in class-map the only way to block https or Layer 7 protocols?
I look forward to your earliest response.
thanks.
Hi Zeeshan,
Good to hear you figured it out. Did you add your GRE interface to a zone? Connections to the router itself should match the ā€œselfā€ zone.
Your HTTP and HTTPS traffic matches match protocol tcp which is why it’s permitted. You could try to create an additional class-map which includes match protocol http and match protocol https, add it before your vpn-cmap class-map, and drop it. That should block your HTTP/HTTPS traffic but still inspect all other TCP traffic.
Thanks for your response, I’d like to take this moment to appreciate this platform which helps all of us in so many ways. This platform is my goto place to find the easiest explanation to a networking concept! keep up the good work :slight_smile: .
So, Yes I first put the GRE interface to OUTSIDE Zone due to which communication for BGP neighbor ship wasn’t happening. Then I moved the GRE tunnel to INSIDE zone which established the BGP. however my end goal was to have a separate VPN zones for Spokes and have policy-map/class-maps restricting or limiting traffic between VPN & INSIDE Zones through the policy-map.
For HTTP/HTTPS traffic, I just wanted to test a vpn class-map if by removing the statement match protocol http and match protocol https would restrict http/https access. I’d ideally want http/https to pass through. So my other question is, does match protocol tcp means it will allow all other TCP based protocols? What would be the most efficient way in blocking such L7 protocols? Can I not do something for e.g only allow certain protocols I know I want to communicate between VPN-INSIDE zone e.g (http,https,dns,icmp,ssh, telnet, tacacs) and block all other by default or implicitly?
Also, a bit off topic, while using crypto map for Site-to-Site IPsec VPN, is there a better way to optimize the config on HUB (CSR) considering there will be a lot of spokes connecting to the HUB (CSR) ? any pointers or best practice will be really appreciated.
Once again, thank you so much for your guidance.
Zeeshan
Hello Zeeshan
As Rene mentions in his post, the GRE interface should be in the ā€œselfā€ zone since traffic to and from this interface are destined and originate from the device itself. Remember that this is the interface to which the tunnel terminates, and all tunnel termination procedures are destined to this interface. The tunnelled traffic (the tunnel interface that is) can and should be in a different zone.
Yes. Any upper layer protocol that uses TCP will be allowed unless specifically indicated in another class map.
You can indeed choose which protocols to allow and which not to allow. You must keep in mind that you can specify protocols of various layers of the OSI model. So if you want to allow TCP for example, but you want to exclude the use of HTTP and HTTPS, then you can:
If you will have many spokes, then the most appropriate technology to use is DMVPN, which is specifically designed to provide you with multiple GRE tunnels using multipoint GRE (mGRE) which can easily add spokes without the need for extra configurations on the hub. You simply configure another spoke and add it. You can apply IPSec security on a DMVPN topology to ensure security and confidentiality. For more information, take a look at the series of lessons on DMVPN starting with these:
Hi @lagapidis @ReneMolenaar,
Thanks for your response.
I’m still going circles with the match protocol http and match protocol tcp.
below L4 & L7 class-map will allow everything as it allows TCP so i removed this then tried the object-group service for protocols.
class-map type inspect match-any L7-cmap
 match protocol dns
 match protocol ssh
 match protocol http
class-map type inspect match-any L4-cmap
 match protocol tcp
 match protocol udp
 match protocol icmp
I just want below protocols and ports to be allowed for which i tried object group service and used tcp protocols for specific tcp protocols to be allowed. however the HTTP, HTTPS, SNMP traffic doesn’t pass between two zones however icmp and ssh works. please can you help me what am i doing wrong?
object-group service ALLOWED_PROTOCOLS_OGS
 tcp-udp eq domain
 tcp eq telnet
 tcp eq tacacs
 tcp-udp eq 5060
 tcp-udp eq 5061
 tcp-udp eq 4569
 tcp eq pop3
 tcp-udp eq 3389
 udp eq 389
 tcp eq 853
 tcp eq 445
 tcp eq 389
 tcp eq msrpc
 udp eq netbios-ns
 udp eq 88
 tcp eq 88
 tcp eq 636
 tcp eq 3268
 tcp eq 3269
 tcp eq domain
 tcp eq 464
 udp eq 464
 tcp range 49152 65535
 udp eq ntp
 tcp-udp eq 443
 tcp-udp eq echo
 icmp
 tcp eq 22
 tcp eq 443
 tcp eq www
 tcp eq 161
 tcp eq 162
 class type inspect ALLOWED_PROTOCOL_CMAP
  inspect
 class class-default
  drop
  inspect
 class class-default
  drop
class-map type inspect match-all ALLOWED_PROTOCOL_CMAP
 match access-group name ALLOWED_PROTOCOLS
ip access-list extended ALLOWED_PROTOCOLS
 permit object-group ALLOWED_PROTOCOLS_OGS any any
 deny   tcp any any
appreciate your support.
Z
Hello Zeeshan
In your L4 and L7 class-map configuration, your class-map is inspecting traffic and not dropping it. As Rene pointed out in the above post, you should create an additional class-map that matches the HTTP and HTTPS protocols, and drops them. This way all TCP will be allowed, but HTTP and HTTPS will not be. Just make sure that this class-map appears before the matching of TCP. This way, only HTTP and HTTPS traffic will be dropped and not other forms of TCP traffic.
It appears that your object groups are created correctly, and since you are using inspect for your class maps and policy maps, all the protocols/ports in the object group should be allowed to traverse one zone to another. The fact that they don’t, gives me the impression that they may somehow be caught by the class-default drop statement. Try removing this and see the results. Also, try to replace the object group with a single statement for HTTP within the access list to see if that makes a difference. By making these changes and seeing what is allowed or disallowed will help you in pinpointing the problem. It could be a configuration error, or simply even a typo in the implementation of the policy map.
Try these out and let us know your results…
Hi @lagapidis,
I’d like to apologies, I was actually testing wrong https port. I had allowed TCP 443 however the application home page I was trying to reach between zones was operating on 4443. So that was an oversight from my end.
however, for above, wouldn’t it be more work trying to find all known protocols & ports to block compared to what I know needs to be allowed only? for e.g I want only these protocols allowed (http,https,dns,icmp,ssh, telnet, tacacs) do I need to create first separate class-map for ā€œALLā€ other TCP protocols that needs to be dropped? and then create a class-map for these (http,https,dns,icmp,ssh, telnet, tacacs) inspecting ? I hope my question makes sense and there is a better way to block.
Thanks again for your support.
Z
Hello Zeeshan
What is being suggested is the following:
 match protocol http
 match protocol tcp
policy-map type inspect MY_PMAP
 class type drop L7-cmap
  inspect
 class type inspect L4-cmap
  drop
The above policy map configuration will drop all HTTP and HTTPS while allowing all other traffic using TCP. Here there is no need to specify each and every L7 protocol you want to allow.
Hello @lagapidis,
Thanks for the explanation. apologies I was all this time imagining the policy map is still inspecting L4-cmap :man_facepalming: its clear now, many thanks! :slight_smile:
Zeeshan
I am trying to get a VPN to work with these zone based firewalls. The VPN is not configured on the router. The source of the VPN is elsewhere and the destinaton is on the customer lan.
If i use the config below when the VPN has already been established, the VPN does not drop.
If i apply the config below, and then restart the VPN, it wont establish.
I have read as much as i can, i believe i am making an exception and passing the VPN traffic, but it just does not work.
Any thoughts suggestions would be welcome
! policy-map
policy-map type inspect INSIDE-TO-OUTSIDE-POLICY
 class type inspect VPN
  pass
 class type inspect INSIDE-TO-OUTSIDE-CLASS
  inspect
 class class-default
  drop log
! policy-map
policy-map type inspect OUTSIDE-TO-INSIDE-POLICY
  pass
 class type inspect OUTSIDE-TO-INSIDE-CLASS
  inspect
 class class-default
  drop log
class-map type inspect match-all VPN
 match access-group name Bespoke_VPN
class-map type inspect match-any INSIDE-TO-OUTSIDE-CLASS
 match access-group name Egress
class-map type inspect match-any OUTSIDE-TO-INSIDE-CLASS
 match access-group name Ingress
ip access-list extended Bespoke_VPN
10 permit udp any any eq isakmp
20 permit ahp any any
30 permit esp any any
40 permit udp any any eq non500-isakmp
